How to split two sets of curves
There is a node called ‘GroupCurves’ in the Archilab package which will give you a sublist of the outer and inner loop. This post by also gives a method for doing so via Design script: Grouping Curves with Design Script.
Once grouped you can search the forum for ‘hole in floor’ and similar terms to find posts to edit the sketch lines to create the opening.
