I am using an image parameter for QR codes. When elements are copied, the existing image parameter comes with it. If the copied element gets a new QR code image, no problem, it writes over the old one. If the copied element does not get a QR code, the old one stays with it.
How can I clear the image parameter, or set it to “None” ?
Nice idea, but it didn’t like Null or empty string, or even empty list.
In the element properties for the image I am able to enter there to clear it, but the node does not want to pass that, because it is text.
So the error message says that it’s looking for a “Double” which just like in Revit that once you change a number parameter you can’t make it (none) again… I don’t think
