hi all,I want to put some sleeves on rebar,but I can’t select any point of rebar.
Could u please tell me how to select the centroid point(or start point,end point )of a vertical rebar?
Thanks.
(not using bouding box)
Thanks.
we can select start point of other element,but can’t select any point of rebar?
could anybody tell me y?
Have you tried this approach:
@598773623 I think the centerline curve method mentioned by Dimitar above is available in a package called “BIM4Struc.Rebar” by @Dieter_Vermeulen
@598773623 @Einar_Raknes Yes, in the BIM4Struc.Rebar package there is node called Rebar.GetCenterline, which returns the sketch curve of a selected set of rebar.
@Einar_Raknes @Dimitar_Venkov @Dieter_Vermeulen Thank u very much!
