I want to select all the projection/crossing profile labels in Civil3D dynamo. Is there a way to do this?
The Arkance Systems Node Libray contains a SelectSimilar node which you could use to make a selection.
Thank you, that works. The only downside is that it requires manual action to select them. It would be even better if no input were required and it could automatically filter them by type. I just can’t find a way to filter out the type labels.
That is right, but you only need to select one object with the Select Object node and then you get all others.
