How to select all elements from a category at each level?
Hello ! I would like to select all elements from some categories (beams, columns, foundations…) in order to export all my structure parameters to excel. I tried to do as in the next picture but it doesn’t work and I can’t find my mistake ! Does somebody know how to fix it ?
My script was working when I was just selecting all elements from a category without level distinction.
Thank you in advance for your help !
Antoine
Hey Anotnie
Not sure why that is not working for you, it works fine for me (see purple group in the image) maybe re-download Clockwork?
You could try the other method in my image, gives you the same output.
Hope this helps
Thank you for your answer ! I tried to re-download the clockwork pack but it still did not work, I don’t know why ! Is the 0.9 version the good one ?
Then I tried the other method, and it works ! Thank you very much ! :slight_smile:
Glad it worked for you :slight_smile:
Im using Dynamo Version 1.0 in Revit 2015, dont know if that is the cause for you.
yes, it’s work, but how can i use it to isolate them in the model or in the view
Beat to start a new topic, as this is solved and hasn’t been discussed in 2 years.
