How to see my works in revit [2024] workflow
Hello everybody,
I am new in Dynamo and I just started working on it. But, the fact is how we are able to see our models from Dynamo workflow to Revit workflow simultaneously as well? . I should mention that my revit version is 2024.
Thank u in advance for your help!
Hi @soroush and welcome here…try with modelcurve by curve or if you only wanna see them turn preview revit on and you can see them as blue lines
Hi @sovitek ,
Thank you for your reply.
yea I just want to see it.
by set preview on, you mean this? . If so, it does’nt work yet…
yes exackly…Hmmm strange it should…try restart…
@sovitek I guess ,it’s kinda graphic issue. I changed my visual style into render and it appears just as a node!
I’m going to guess that this is correctly displaying, but things in your Dynamo graph are say 10 units, and Revit is set to utilize mm, so thing are ~10mm cubed.
Try setting your units to M or Feet and restart Dynamo to see if it cleans things up. :slight_smile:
U are absolutely right and I haven’nt noticed about it. Many thanks!
