Good evening, I would like to know what my code is missing to rename line styles. I attach the image so you can help me.
Thank you
Translated by moderators. Original text below.
Buenas noches quisiera saber que le falta a mi código para renombrar estilos de líneas. Adjunto la imagen para que me puedan ayudar.
Gracias
@desm30, please keep future posts to English, as that is the official forum language. You can post your original text as well after a line as I have done in the edit above. This is a requirement for search to work correctly.
Thanks.
You can try to use Element.SetName in clockwork package. or can simply create a python script with this line:
lines = IN[0] newNames = IN[1] for line in lines: try: line.Name = newName x=[] except Exception,e: x = e if x: OUT = x else: OUT = lines
**Havent tested out the code so use it at your own risk
