How to remove polygons from an object created using a mesh
I created a geometry through a mesh using a routine in dynamo, but when the element appeared in the Revit interface it appeare
d with several polygons (as you can see in the image), does anyone know how to remove it?
you can try to use the Dynamo MeshToolkit package
Hi @c.poupin is that 2024 as i cant get meshtoolkit to work in 2024…
I have the same problem with Revit 2024
thx then it isnt me there do something wrong ;)…
I find this post here …
We are very close to shipping an updated Mesh Toolkit and our sincere apologies it’s taken this long :frowning: The .NET upgrade took a monumental amount of effort and was “all hands on deck” for months on end.
The reason it wasn’t a simple update was that binaries for our geometry kernel that Mesh Toolkit uses changed and required some deeper updates.
Could you share the dynamo (DYN) routine you are using? please
I didn’t save it because it’s a simple dynamo script with only 8 nodes (see the screenshoot)
the first node is File Path node
Can you share with me the script used in the “code block” NODE.
I tried to create the routine in dynamo based on your photo, but I was unsuccessful.
can you post your dyn here ?
yes
Homenovo codigo.dyn (10.6 KB)
I would not use Dynamo for this, would use Rhino and convert the mesh to BRep geometry and then you can import to Revit later
Hi @joseermersongoncalve
you can find more information about code block here
https://primer.dynamobim.org/en/07_Code-Block/7-1_what-is-a-code-block.html
here the dyn fixed (use DynamoSandbox2.16)
Homenovo codigo.dyn (16.4 KB)
Thanks for the recommendation, I will study the software
Thanks for the help
Update here is that now both versions of MeshToolkit are uploaded, meaning you can once again use it in any version of Dynamo :star_struck: Refer to the link above, or the table below:
