How to remove empty list or null value from list
hi all,
I have read thru the post below and some others post in the forum,
tried List clean , clear list but the empty list and null value is still there , would need some help to point to my mistake, thank you all
Don’t use list levels on your data set - basic auto lacing with no level indicated and a List.Clean should work.
Thanks a lot Jacob, that worked ! been stuck on this for hours…
Hey if possible can you send the Dyn for this?
You want the .dyn for a list clean node?
ya
Right click on white space.
Type “List.Clean”
Select the option it gives you.
4 year old zombie topic - if there is a question or something which needs more detailed review let’s move it to a new topic.
Thanks - your friendly neighborhood moderator guy. :slight_smile:
