How to perform Solar Analysis on individual Curtain Wall Panels using Dynamo?
Hi everyone,
I am currently working on a project in Revit with a large glass facade (Curtain Wall). I need to perform a solar analysis to evaluate the solar radiation/heat gain falling on each individual glass panel separately.
My goal is to calculate and extract the solar insolation values for every single panel, and ideally, write that data back to a parameter in the panels using Dynamo.
Has anyone tackled a similar workflow? Which specific packages or nodes (e.g., Solar Analysis for Dynamo, Ladybug for Dynamo) would you recommend to achieve this panel-by-panel extraction?
Any advice, sample scripts, or guidance on the logic would be greatly appreciated!
Thanks in advance.
Hi Mohammad, welcome :wave:
You could check out the Youtube video by @GavinNicholls
Sun hour analysis using Dynamo and Revit (no Ladybug)!
