How to make a simple clashtest?
how can i make a simple clashtest f.e. doors vs ceilings and filter out intersecting elements
KR
Andreas
Hi Andreas does it work if set lacing to cross in the intersect nodes
@sovitek
i get “something”
how can i relate that to an object.
KR
Andreas
then i would use does intersect or try bimorph fast intersecting nodes…
and here with bimorph much faster with big dataset…
@sovitek ,
it remains empty
in the background you can see the intersection…
my pythoncode works well
import sys
clr.AddReference('RevitAPI')
#collector
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Doors)
all_doors = collector.WhereElementIsNotElementType().ToElements()
collectors = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Ceilings)
all_ceilings = collectors.WhereElementIsNotElementType().ToElements()
OUT = all_doors, all_ceilings
KR
Andreas
Hej …hmm probably you need set bimorph to longest…is something here better…
@sovitek ,
i have no idea
KR
Andreas
does it work if you flatten your solids before bimorph
@sovitek ,
i get output but it is still wrong…
3 of them are in a clash
KR
Andreas
not sure then,is it the latest bimorp version…you are welcome to share your sample rvt file, and i can see if i can get it to work…
@sovitek
Projekt99.rvt (1.2 MB)
maybe it is realy bimmorphenodes
KR
Andreas
Yeah it could be…but a funny thing is it actuelly only see 2 clashes in when in 3d and BIMorph give 3 i guess its becoarse that node intesect symbolic lines as well (doorswing in plan) the ootb way gives 2 becourse its solid vs solid without lines…
@sovitek ,
no idea…
it does not work, intersection is just 1cm around!
i get no result
KR
Andreas
hmmm try remove solid union from your ceiling so you have 11 solids/ceilings, I guess you only have 8 doors, what does element solid from doors give you ? try set solid union to list level 2, and try cross in your intersect node and L2 in your mask…what does bimorph give you ?
andreasHome.dyn (26.9 KB)
