How to make a cube by vertices?
Hi, all.
I have 8 vertices and would like to make a cube using these vertices.
Later, I will get surfaces from the cube.
However, I have some trouble making the cube.
I tried to use other nodes but failed.
Does anyone know how to make a cube using 8 vertices?
Checking2.dyn (8.7 KB)
@Ella Please drop your dyn file
@salvatoredragotta
ok, I just attached file :slight_smile:
What are you selecting with the Select Model Element node
@salvatoredragotta
I forgot to explain. I selected one column and I would like to remake this column by shared coordinates.
try this:
Checking2 - v2.dyn (20.8 KB)
If it’s orthagonal you could just get the bounding box.
@salvatoredragotta
@jacob.small
Thank you both for your comments.
I tried salvo’s script and it was successful! Thank you.
I also found the simple way to solve this problem based on the Jacob’s comment.
I extracted minimum and maximum point from the point list and created bounding box which can be converted into the Cube.
Anyway, thank you for helping me!
Helllo Everyone,
I want to create a cuboid by 8 points and accepted answer in this post isn’t helping.
If I use Element.BoundingBox then the output I need is not correct. But I am able to get 8 corner points from a scope box and I just want a cuboid from these 8 points.
please check the snap for better understanding.
any suggestions are welcome.
Thanks in Advance
One thread only for a problem at once please.
Refer here:
