Hi everyone,
I need some help with manipulating lists. Specifically, I have a list where I need to insert the text ‘State Property’ at certain indices provided in an image. After that, I plan to insert ‘Council Property’ at the remaining indices.
I’m looking for a way to do this in one step. How can I create a list where the correct values appear at the specified indices in a single operation? Any advice or code examples would be greatly appreciated!
Thanks in advance for your help!
For bulk replacement, you will need the Clockwork package and this node:
I’ve tried that node as well, but didn’t work for me.
What you show in the screenshot might be due to levels. Get rid of the square bracket in the code block with the 0 to 5 sequence. 0…5 is already a list. The square brakcets put that list into another list. that should solve it. Alternatively, you can set the seq input to Level 2.
A simple Design Script solution:
The code:
lst;
indexes;
replacement;
result =
[Imperative]
for (i in indexes)
lst[i] = replacement;
return lst;
