How to get contour lines from toposolid?
looks like RevitLookup tool can get contour lines …
how to get contour lines from toposolid - Autodesk Community - Revit Products
edit: need to add options.View = doc.ActiveView;
you can use GetDependentElements() method
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
topoSolid = UnwrapElement(IN[0])
c_filter = ElementClassFilter(clr.GetClrType(DB.CurveElement))
lines = [doc.GetElement(xId) for xId in topoSolid.GetDependentElements(c_filter)]
OUT = [c.GeometryCurve.ToProtoType() for c in lines]
EDIT : error of understanding, this method does not allow getting isolines
thanks c.poupin, are you sure all contour lines listed? should be more (primary and secondary), not just boundary
Edit :
ok I was fooled by a French translation/interpretation error, (contour lines => isolines)
so actually my method is actually not the right one
seems you still have to get it from GeometryElement
