Hi, Everyone
How to generate the Random color by given only the value of number of color ( ie. 5 shade, 3 shade).
Hi, Everyone
Refinery toolkit package has a good node for random contrasting colors, called ‘ContrastyColor’ if I am not mistaken.
hi everyone,
i’m working on putting some random colors to a curtain wall mullions, nevertheless i’m having this error message, I’m lost since I’m not sure whats the problem, can someone give me a hand please?, thanks
Select a mullion in your project; do you see a material parameter in the properties pallet? If not and you have to open the element type dialog then you need to work with the element types, not the element instances. Note that randomizing with element types is likely not ideal using this method.
