Is there any way to detect if an element is in two rooms?
If I use Element.Room, I get the room where Room Calculation Point is placed, so I tried with Tool.GetSurroundingElements but it returns an Empty List (regardless of the value of tolerance) <br class=“Apple-interchange-newline” />
Thanks Kulkul and Vikram! The first solution works perfectly for me. I can’t test the second one because there are a lot of elements in my project and the calculation time is too high.
I have the following problem. As Kulkul indicated, in the node “Elements in Room” I enter as input:
Furniture
Rooms
If I check the Rooms category I get an output of 181 elements The output of “Elements in Room” is a list of 11 elements. I would like to know to which room each of these 11 elements belong
