Hi!
I have been following the tutorial http://jbdynamo.blogspot.com/2015/11/ammo-cutting-objects-to-topography.html
But I get the error from code block a[1] “index outside given range”. I have tried so many different things now, and searched about the problem without finding anything. Can you guys please help me? What does the block a[1] actually means?
Thank you!
Hi @Ericasp,
Try with a[0][0] in the code block.
Well, composing Martin’s answer, a[1] means from list a, retrieve element 1. Suppose you have a list a = [object1, object2, object3]
a[0] will return object1 (in dynamo, python and DesignScript, counting starts at 0)
a[2] will return object3
a[3] doesn’t exist, so index out of range
Thank you for the replies!
I have no error now, but still the model doesn’t behave as the example.
The generic model I created with Dynamo just sits on the bottom.
Any ideas what the problem might be?
If I change the thickness to a higher number I get the slice of the generic model, though the slice is done on the “wrong” side, see my attachment. Any ideas?
