Hi
How to create rectangular face or curve from special face or curve
result is the biggest rectangular
Thank!!!
Hi
Thank!!!
I can help you with logics, maybe it helps you…
Hi
I think rectangular need 4 points
I mean that you can calculate 2 main points (red circles), than you can create other two points (green) taking coords from main (red) points.
If your original rectangles are axis aligned you could use the BoundingBox nodes. If they are not axis aligned you will have to align them first to be able to use BoundingBoxes.
Hi! boundingBox is so good, but element slanted angle: α
boundingbox not folow element
How to get boundingbox folow element direction?
There are multiple approaches, but I think this one is very suitable for you:
Hi! Thank you
Solved this
