How to create diagonal wall with dynamo
Here an example
edit_wall_profile
python code (IronPython3 or PythonNet3)
No solution with CPython3 (especially with Revit 2024)
import Autodesk.DesignScript.Geometry as DS
#import Revit API
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
class CreateFailureAdvancedHandler(IFailuresPreprocessor):
    __namespace__ = "CreateFailureAdvancedHandler_jdtR0sA"
    def PreprocessFailures(self, failuresAccessor):
        failMessages = failuresAccessor.GetFailureMessages()
        if failMessages.Count == 0:
            return FailureProcessingResult.Continue
        transName = failuresAccessor.GetTransactionName()
        if failuresAccessor.GetSeverity() == FailureSeverity.Warning:
            for currentMessage in failMessages:
                failuresAccessor.DeleteWarning(currentMessage)
        elif failuresAccessor.GetSeverity() == FailureSeverity.Error:
                failuresAccessor.ResolveFailure(currentMessage)
            return FailureProcessingResult.ProceedWithCommit
            pass
wall = UnwrapElement(IN[0])
offset_value = 5
# offset point
sketch = doc.GetElement(wall.SketchId)
curveArray = sketch.Profile[0] # assuming there is only 1 loop
# get top line
sort_curves = sorted(curveArray, key = lambda x : x.Evaluate(0.5, True).Z)
top_line = sort_curves[-1]
rest_curves = sort_curves[:2]
# get points on top line
pt1_old = top_line.GetEndPoint(0)
pt2  = top_line.GetEndPoint(1)
# find adjacent vertical line
vertical_line = next((c for c in rest_curves if c.Project(pt1_old).Distance < 0.01), None)
# bottom point on vertical line
pt3 = next((vertical_line.GetEndPoint(i) for i in range(2) if  vertical_line.GetEndPoint(i).DistanceTo(pt1_old) > 0.1), None)
new_pt = pt1_old - XYZ(0,0,offset_value)
new_top_line = DB.Line.CreateBound(new_pt, pt2)
new_vertical_line = DB.Line.CreateBound(pt3, new_pt)
sketchEditScope = SketchEditScope(doc, "Update Wall")
sketchEditScope.Start(sketch.Id)
t = Transaction(doc, "Update Wall")
t.Start()
# Remove elements referenced by the found lines.
doc.Delete(top_line.Reference.ElementId)
doc.Delete(vertical_line.Reference.ElementId)
# Model curves creation automatically puts the curve into the sketch, if sketch edit scope is running.
doc.Create.NewModelCurve(new_top_line, sketch.SketchPlane)
doc.Create.NewModelCurve(new_vertical_line, sketch.SketchPlane)
t.Commit()
sketchEditScope.Commit( CreateFailureAdvancedHandler() )
t.Dispose()
OUT = wall
