Hi
I have 2 point grids for each level and I would like to create structural columns between each vertical matching point . How could I do this using the python code block?
Any suggestion would be highly appreciated.
I don’t think you need python for this, you can use OOTB nodes to place column families and then edit parameters like height, thickness, etc. afterwards (all in 1 script).
Could you maybe elaborate why you think a python script is needed?
Kind regards,
Daan
I agree - no need for Python here.
https://dictionary.dynamobim.com/#/Revit/Elements/StructuralFraming/Create/ColumnByCurve
Hi , thanks for your answer, I would like to use the python node since I have a script that updates the amount of points every time the number of subdivisions for every portico changes. Every point has its matching pair on the level immediately above it. So I would find it more convenient if I could automatically call the revit api method to create columns inside my script.
Thanks for your suggestion , but I would still find it very useful to use either the preinstalled OOTB nodes or the Revit Api Methods to create the colums inside my python script. Would you happen to know if its possible to use the OOTB nodes inside the python node?
import sys
import System
clr.AddReference("RevitAPI")
famType=UnwrapElement(IN[0])# get the column family type to use
columns=FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralColumns).WhereElementIsElementType().ToElements()#get all column types
levels=FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Levels).WhereElementIsNotElementType().ToElements()#get all levels
for column in columns: #get all column types and select a specific type for the new column
column_name=column.get_Parameter(BuiltInParameter.ALL_MODEL_FAMILY_NAME).AsString()
if column_name=="Pilar HEB":#select the appropriate column name
column_type=column
if famType.IsActive == False:#sometimes you need to first activate the familysymbol for the column type that you are using
famType.Activate()
doc.Regenerate()
column_=doc.Create.NewFamilyInstance(XYZ(20,0,levels[0].Elevation),columns[0],levels[0],Structure.StructuralType.Column)
top_offset=column_.get_Parameter(BuiltInParameter.FAMILY_TOP_LEVEL_OFFSET_PARAM)
top_offset.Set(0)#set to no offset from level immediately above
OUT=column_
