How to copy phases of a revit project
Hello guys,
i have a problem :). I want to copy the phases from a revit link. The link has 19 phases and I want them to be transferred to my file. Copying 19 phases manually is very long. Is there a script that allows you to copy the phases of a link and transfer them to my file?
thx
i don’t find any phase creation method in rvt 25. so likely, there isn’t.
:frowning:
phase inherit Element class so DB.ElementTransformUtils.CopyElements() should be possible between documents
it will be necessary to check if the order is preserved
after testing it did not work :roll_eyes:
JOTools addin.
mm ok thanks I’ll look for it
0 result,
@c.poupin it throws a “Project Phase cannot be copied” exception which i don’t find it documented in rvt 2025’s dll.
@Lorenz751 I never tried it, so tested it and…
although there is a checkbox for Phases in de add-in it doesn’t work, so don’t bother
downloading the add-in
ok thanks :slight_smile:
I believe I used to accomplish this by binding a link… :thinking:
ooh…where?
I didn’t share it outside of the company I worked at then, and I don’t have too much recollection of how it was done either - this predated my time on the Dynamo forum so we are talking 10(ish) years ago now and my brief exploration didn’t turn up much.
