I created polyline with a python script. But when I want to use with other Dynamo node, I have the following message : Autodesk.DesignScript.Geometry.PolyCurve is expected but SystemObject is used
How can I manage this issue?
Thank in advance
Bruno
Hi Bruno, welcome!
Use the ToProtoType() method built into Dynamo for Revit
Example code
import random
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import PolyLine, XYZ
ri = random.sample(range(1000), 27)
iters = [iter(ri)] * 3
points = [XYZ(x, y, z) for x, y, z in zip(*iters)]
pl = PolyLine.Create(points)
OUT = pl, pl.ToProtoType()
Result
Hi Mike,
Thanks a lot. I just add the following lines and it works fine.
clr.AddReference(‘RevitNodes’)
Best regards
Bruno
