So I used the “Lunchbox point to string” node, but I want it in a normal list form as shown. My workaround was through excel, but I’m sure there is an easier way.
Use the string split node, you just put your string in the input and a string containing the separator, in your case a comma. Your original points list would already be in this format though so not sure what you are trying to achieve but hope this helps.
Michael
Hi Amin,
Have a look in Help>Samples>Core>CoreStrings for some other actions you can perform on strings.
Thanks a lot
Is there a way to go the other way? A list of strings to strings separated by a comma?
