unexpected token ‘’
Get this whatever I do…
Syntax should be correct?
Thanks John
/ is an escape character, try "//"
any other suggestion?
Don’t use str as a variable, or any of these:
https://docs.python.org/2/library/functions.html
… and please paste, and format your code if you expect anyone to test it.
Thx for getting back to me.
I did not know that, but the guy who posted about it was using str.
anyhow i still get the same issue
How do i create the code input method in the comment box?
dataEnteringNode = IN
Names = IN[0]
spaceList = []
output = []
for i in Names
j = UnwrapElement(i)
Conc = ""
for k in range(1,len(j)):
Conc = Conc + j[k] + "-"
spaceList.append(str)
output.append(spaceList)
OUT = output
[http://bimandothers.blogspot.nl/2016/12/dynamo-for-construction-4d-planning-and.html]
what i am trying to get to
You’re lacking a “:” after “Names” on line 11
