How to check whether postable command ID_INTERFERENCE_CHECK is completed or not?
Hi all,
I want to check whether the interference check dialog box is closed or not and I want the script to be executed after or once the interference check report is generated.
Below is the snip that explains the requirement
Below is the code that I am working on:
import sys
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\Lib')
import System
clr.AddReference("RevitAPI")
import time
app = uiapp.Application
def tolist(obj1):
	if hasattr(obj1,"__iter__"): return obj1
	else: return [obj1]
RunIt = IN[0]
if RunIt ==  True:
	CmndID = RevitCommandId.LookupCommandId('ID_INTERFERENCE_CHECK')
	CmId = CmndID.Id
	uiapp.PostCommand(CmndID)
	errorReport = True
	#time.sleep(delaysec)
	errorReport = False
#Assign your output to the OUT variable
OUT = errorReport
I think you will need to add an event listener to Dynamo, but that said this code is already so far along that moving to an add-in or zero touch node would be preferable in terms of stability and performance (ie: listeners need to be closed or you will crash when closing files).
