I am new to dynamo. I want to assign workset to elements those elements should categorized based on system type. I tried but didnt get result…
…CHECK THE ATTACHED JPG FOR REFERENCE…I would use the workset nodes from Archilab and Element.SetWorkset from Clockwork.
In this graph I grouped the families according to their Service Type and then manually set different workset for every group.
Even better would be to associate every Service Type to a Workset. Here workset names match exactly with service type. If it doesn`t match (i.e. your workset names are numbers) you need a bit more of work, but I think you got already enough input
THAKS FOR YOUR REPLY. I will check
Thank you i ll check
Hi there
I was trying to use this graph, but for me its not working, can you guys explain why that is?
@lucamanzoni can you help?
The input type of value should be a number. Workset.Id will give you the ID and try to connect to value.
Can you please try to convert int to string or type in code block 360 and connect it?
A Codeblock did the Trick! Thanks a lot @Deniz_Maral
