How to auto size in excel after export from dynamo?
Only one topic in 2017 but it seems unsolved.
https://forum.dynamobim.com/t/bumblebee-autofit-excel-columns/16994
Does anyone know how to make the cell in excel auto fits the text after export?
thanks…!
I assume it would be possible to make a list of all posible characters with their pixel size. Then you can check for the longest word/value within your column and set it to this value. (note: I assume you try to set a new column with instead of the standard 8,43 px)
So I found this post where you can set a column width. So you only have to find a solution the find the longest word so it can be set as the column width.
It looks like this is a relatively simple fix in the Bumblebee export node.
We simply need to add for the worksheet to autofit after writing. (One additional line of code)
Here is the code difference:
And the code below would replace the python in the highlighted node in these screenshots:
# Copyright(c) 2016, David Mans, Konrad Sobon
# @arch_laboratory, http://archi-lab.net, http://neoarchaic.net
import sys
import System
from System import Array
clr.AddReferenceByName('Microsoft.Office.Interop.Excel, Version=11.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c')
from Microsoft.Office.Interop import Excel
System.Threading.Thread.CurrentThread.CurrentCulture = System.Globalization.CultureInfo("en-US")
from System.Runtime.InteropServices import Marshal
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
from os import path
assemblies = System.AppDomain.CurrentDomain.GetAssemblies()
path1 = [a.Location for a in assemblies if 'bumblebee,' in a.FullName][0]
path2 = System.IO.Path.GetDirectoryName(path1).rsplit('\\',1)[0]
bb_path = '%s\\extra\\' %path2
sys.path.append(bb_path)
import bumblebee as bb
import os
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
filePath = IN[0]
runMe = IN[1]
byColumn = IN[2]
data = IN[3]
if filePath != None:
	if filePath.GetType() == System.IO.FileInfo:
		filePath = filePath.FullName
def LiveStream():
	try:
		xlApp = Marshal.GetActiveObject("Excel.Application")
		xlApp.Visible = True
		xlApp.DisplayAlerts = False
		return xlApp
	except:
		return None
def SetUp(xlApp):
	# supress updates and warning pop ups
	xlApp.Visible = False
	xlApp.ScreenUpdating = False
	return xlApp
def WriteData(ws, data, byColumn, origin):
	def FillData(x, y, x1, y1, ws, data, origin):
		if origin != None:
			x = x + origin[1]
			y = y + origin[0]
			x = x + 1
			y = y + 1
		if y1 != None:
			ws.Cells[x, y] = data[x1][y1]
                #new line to autofit columns, could be useful to add a toggle
		ws.Columns.AutoFit()
		return ws
	# if data is a nested list (multi column/row) use this
	if any(isinstance(item, list) for item in data):
		for i, valueX in enumerate(data):
			for j, valueY in enumerate(valueX):
				if byColumn:
					FillData(j,i,i,j, ws, data, origin)
					FillData(i,j,i,j, ws, data, origin)
	# if data is just a flat list (single column/row) use this
			if byColumn:
				FillData(i,0,i,None, ws, data, origin)
				FillData(0,i,i,None, ws, data, origin)
	return ws
def ExitExcel(filePath, xlApp, wb, ws):
	# clean up before exiting excel, if any COM object remains
	# unreleased then excel crashes on open following time
	def CleanUp(_list):
		if isinstance(_list, list):
			for i in _list:
				Marshal.ReleaseComObject(i)
			Marshal.ReleaseComObject(_list)
		return None
	wb.SaveAs(unicode(filePath))
	xlApp.ActiveWorkbook.Close(False)
	xlApp.ScreenUpdating = True
	CleanUp([ws,wb,xlApp])
	return None
def Flatten(*args):
    for x in args:
        if hasattr(x, '__iter__'):
            for y in Flatten(*x):
                yield y
            yield x
def WorksheetExists(wb, name):
	for i in wb.Sheets:
		if i.Name == name:
			return True
			break
			continue
	return False
if isinstance(data, list):
	if any(isinstance(x, list) for x in data):
		data = list(Flatten(data))
live = False
if runMe:
	try:
		errorReport = None
		if filePath == None:
			# run excel in live mode
			xlApp = LiveStream()
			live = True
			wb = xlApp.ActiveWorkbook
			# run excel from a file on disk
			xlApp = SetUp(Excel.ApplicationClass())
			live = False
			# if file exists open it
			if os.path.isfile(unicode(filePath)):
				xlApp.Workbooks.open(unicode(filePath))
			# if file doesn't exist just make a new one
				wb = xlApp.Workbooks.Add()
				if not isinstance(data, list):
					# add and rename worksheet
					ws = wb.Worksheets[1]
					ws.Name = data.SheetName()
					for i in data:
						# if worksheet doesn't exist add it and name it
						if not WorksheetExists(wb, i.SheetName()):
							wb.Sheets.Add(After = wb.Sheets(wb.Sheets.Count), Count = 1)
							ws = wb.Worksheets[wb.Sheets.Count]
							ws.Name = i.SheetName()
		# data is a flat list - single sheet gets written
			if WorksheetExists(wb, data.SheetName()):
				ws = xlApp.Sheets(data.SheetName())
			WriteData(ws, data.Data(), byColumn, data.Origin())
			if not live:
		# data is a nested list - multiple sheets are written
			sheetNameSet = set([x.SheetName() for x in data])
			for i in data:
				if WorksheetExists(wb, i.SheetName()):
					ws = xlApp.Sheets(i.SheetName())
				WriteData(ws, i.Data(), byColumn, i.Origin())
			if not live:
	except:
		xlApp.Quit()
		Marshal.ReleaseComObject(xlApp)
		# if error accurs anywhere in the process catch it
		import traceback
		errorReport = traceback.format_exc()
		pass
	errorReport = "Set RunMe to True."
#Assign your output to the OUT variable
if errorReport == None:
	OUT = "Success!"
	OUT = errorReport
I went ahead and added this discussion to the Github issue on Bumblebees repo too.
thank you, it works!!!
