How to add the parameter "length of each bar" in rebar container Revit API
Hi everyone,
I filled up my container with my creted rebars, but I noticed that the parameter " length of each bar " is missing as shown in the image below, so how can I set it please?
rebars
import sys
import math
import System
from System.Collections.Generic import IList, List
clr.AddReference('RevitAPI')
out_curv = IN[0][0].ToRevitType()
out_path = IN[0][1].ToRevitType()
iner_curv = IN[0][2].ToRevitType()
iner_path = IN[0][3].ToRevitType()
cover = IN[1]/0.3048
rebar_type = UnwrapElement(IN[2])
Hook_type = UnwrapElement(IN[3])
host= UnwrapElement(IN[4])
spacing = IN[5]/0.3048
# compute the rotation angle
def rebar_rotation(circle, space):
    sweepAngle = (space * 360) / (circle.Radius *  2 * math.pi)
    return sweepAngle
out_angle = rebar_rotation(out_path, spacing)
iner_angle = rebar_rotation(iner_path, spacing)
# rotated rebars count
out_count = int(math.ceil(360/out_angle))
iner_count = int(math.ceil(360/iner_angle))
# get rotated curves
out_rot_curvs = []
for i in range(0, out_count):
    a= i*out_angle
    rot_curv = Transform.CreateRotation(XYZ.BasisZ, a*2*math.pi/360)
    out_curvs = out_curv.CreateTransformed(rot_curv)
    out_rot_curvs.append(out_curvs)
iner_rot_curvs = []
for i in range(0, iner_count):
    a= i*iner_angle
    iner_curvs = iner_curv.CreateTransformed(rot_curv)
    iner_rot_curvs.append(iner_curvs)
#create horizontal line needed to create normal vector
out_line =Line.CreateBound(out_curv.GetEndPoint(0), iner_curv.GetEndPoint(0))
iner_line =Line.CreateBound(iner_curv.GetEndPoint(0), out_curv.GetEndPoint(0))
rot_90 = Transform.CreateRotation(XYZ.BasisZ, math.pi/2)
out_line = out_line.CreateTransformed(rot_90)
iner_line = iner_line.CreateTransformed(rot_90)
#get rotated lines
out_Vect = []
    a= i*out_angle
    rot_vect = Transform.CreateRotation(XYZ.BasisZ, a*2*math.pi/360)
    out_vect = out_line.CreateTransformed(rot_vect)
    out_Vect.append(out_vect)
iner_Vect = []
    a= i*iner_angle
    iner_vect = iner_line.CreateTransformed(rot_vect)
    iner_Vect.append(iner_vect)
#create normal vectors
out_Vect = [(i.GetEndPoint(0) - i.GetEndPoint(1)).Normalize() for i in out_Vect]
iner_Vect = [(i.GetEndPoint(0) - i.GetEndPoint(1)).Normalize() for i in iner_Vect]
# create rebars
out_rebars = []
iner_rebars = []
containerTypeId = RebarContainerType.GetOrCreateRebarContainerType(doc, "iner_V_rebar" )
rebarContainer = RebarContainer.Create(doc, host, containerTypeId)
iner_V_crv = List[Curve]()
for c, v in zip(iner_rot_curvs, iner_Vect):
    iner_V_crv.Add(c)
    iner_V_rebar = Rebar.CreateFromCurves(doc, RebarStyle.Standard, rebar_type, Hook_type, Hook_type, host, v, iner_V_crv, RebarHookOrientation.Left, RebarHookOrientation.Right, True, True)
    rebarContainer.AppendItemFromRebar(iner_V_rebar)
    doc.Delete(iner_V_rebar.Id)
    iner_V_crv.Clear()
quantityParameter = rebarContainer.get_Parameter(BuiltInParameter.REBAR_ELEM_QUANTITY_OF_BARS)
containerParameters = rebarContainer.GetParametersManager()
containerParameters.AddOverride(quantityParameter.Id, len(iner_rot_curvs))
iner_rebars.append(rebarContainer)
OUT = iner_rebars
Please check my references below
rebars_container.dyn (18.3 KB)
Shaft_rebar.rvt (3.4 MB)
Thanks.
@christian.stan can you please take a look here?
Thanks.
Here is a doc.Regenerate() after creation of the bars before storage in the container
cordially
christian.stan
@christian.stan
It works perfectly :wink:
It’s strong…in another example I got this parameter without regenerate the doc !!
Thanks.
Hello, I was wondering, if someone was able to change some dimensions values of those Rebar containers? The values I mean ars a,b,c,d,… some of my designers are changing values and I have to rerun my scripts to update my rebars, and I loose all of my tags :frowning:
