for any reason, my roof worklines apear as modelines how can i access them correctly
here just array only:
#functions
def tolist(x):
if hasattr(x,'__iter__'): return x
else: return [x]
#collector
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Roofs)
all_Roofs = tolist(collector.WhereElementIsNotElementType().ToElements())
profiles = [i.GetProfiles() for i in all_Roofs]
curves = [c.get_Parameter(BuiltInParameter.CURVE_ELEM_LENGTH).AsDouble() for c in profiles]
OUT = all_Roofs, profiles, curves
KR
Andreas
The GetProfiles() method returns a ModelCurveArrArray which you will have to iterate through
Try this line
curves = [c.get_Parameter(BuiltInParameter.CURVE_ELEM_LENGTH).AsDouble() for arr in profiles for c in arr]
def tolist(x):
else: return [x]
#collector
#curves = [c.get_Parameter(BuiltInParameter.CURVE_ELEM_LENGTH).AsDouble() for c in profiles]
This is like Inception or perhaps ModelCurveArrays all the way down. I think the better way to try this is to use other methods to get to the geometry.
Add a function. This is not the way I would do it with pure python, however this handles the .NET objects better
def flatten(x):
try:
return [a for i in x for a in flatten(i)]
except:
return [x]
Your collector is assuming FootPrintRoof types - perhaps make it explicit
roofs = (
.OfClass(FootPrintRoof)
.ToElements()
And finally use the GeometryCurve.Length attribute of the ModelCurve to get your elements’ length
OUT = [mc.GeometryCurve.Length for mc in flatten([r.GetProfiles() for r in roofs])]
To keep nesting of multiple roofs use this
modelcurves = [flatten(r.GetProfiles()) for r in roofs]
OUT = [[c.GeometryCurve.Length for c in mc] for mc in modelcurves]
