How do I retrieve the Shared Site parameter for a Link Instance
I am trying to get the name of the shared site for each instance of a linked model. I have tried to use the GetParameterValueByName node and used “Shared Site” as the parameter name. I have also used the below Python code snippet to try and retrieve the shared site, but it returns that it has no value:
parameters.append(element.LookupParameter("Shared Site").HasValue)
The image below shows that the links indeed have a shared site assigned to them:
Here is the dynamo script I created that just returns empty-handed:
Shared%20Site%20Retrieval
Any help will be much appreciated. I feel as if I’m missing something right in font of me.
Can you show the python code?
Hi @charl.pretorius,
This parameter value is accessible by the linkInstance name.
shared%20site
In python :
# Import RevitAPI
clr.AddReference('RevitAPI')
names=[]
rvtLinkCollector = FilteredElementCollector(doc).OfClass(RevitLinkInstance).ToElements()
for rvt in rvtLinkCollector:
	names.append(Element.Name.GetValue(rvt))
OUT = names
shared
@Alban_de_Chasteigner,
Thanks for the solution! I would never have thought that the name property also exposes the shared site. I have trawled through the API docs and nowhere is that made clear.
It’s a pity that it’s just a string combined with everything, but luckily it’s trivial just to trim everything off before the location.
@Nick_Boyts,
The gist of the code is in my original post, but below is the entire snippet for reference, also changed to get the parameter value as a string, which just returns empty strings:
# Import RevitAPI
clr.AddReference("RevitAPI")
elements =[UnwrapElement(link) for link in IN[0]]
sites = [element.LookupParameter("Shared Site").AsValueString() for element in elements]
OUT = sites
5 years later, any way yet in API to change the Shared site parameter passing in a Project location?
