How do i "node to code" this?
I’d like to use DesignScript for the Element.SetParameterByName node.
I have a lot of similar parameters to set, so, to keep it clean im looking at DesignScript.
I am seeing an extra input beeing generated above the a,b,c, inputs in my first attempt.
I tried DSCore.Set.ParameterByName, Revit.Set.ParameterByName and Autodesk.Set.ParametrByName to no avail.
Thnx in advance,
Marcel
Hi @m.rijsmus ,
it goes like this in design script:
element.SetParameterByName(ParameterName,Value);
The great Node to code functionality can help you figure it out :
+1 to Mostafa, and they’ve also made lots of designscript functions more forgiving regarding syntax. One can also write like this:
Can’t remember since what version, though.
Result:
Marcel
