How can I select surface automatically?
Hi. I’m new in dynamo.
I have a solid element like this, and I want to get surfaces list in order.
I got the surface list by exploding the element.
But after modifying the element and running the code, the exploding surface list’s order is changed.
So, is there any better way to select surfaces in order?
Do I have to select all surfaces manually? Can I use vector for auto-selection?
i like this comment!
You can use vectors for the work. The only problem is that what is the order you want.
Thank you for your comment! It solved my problem :slight_smile:
Thank you for your reply. I have seen your blog and I learned much in yours!!
