How can I Group Rebar?
Hi everybody !
I’m doing a rebar layout for a bridge pier, because the spacing of the rebars are different, I want to group them into a Group, like the “Group” tool of “SOFiSTiK Reinforcement Detailing” !
Any help is appreciated , thanks !
Hi @phuongnt1.yame ,
Could you show some screenshots of what you have and what you want to do?
Grouping could mean different things in different contexts.
Thank you for your help! I have made a short video you can check it out, my problem is how to group the rebars together like the “SOFiSTiK’s Group” tool using Dynamo
From the video i understand you want to group by shape and size in but this time in Dynamo?
That’s right, I want it done in Dynamo
Look at List.GroupByKey.
Check out this thread:
Hi, I am looking for the same thing, a way to create the SOFiSTiK RCD Groups via Dynamo. Did you find a solution yet?
Hi, what sofistik does is to use the RebarContainer Class from Revit API. This allow to group rebar items in a group, the only problem is that no edition of the bars candy be done after grouping.
To do it with dynamo you could use a python nose tho create that container
Regards
