How can i define <familiy Type> Parameter in Python?
Hello Dynos,
text is string
yes/no is boolean
Number is float
but What is a family type parameter? a class?
Do you have any examples?
KR
Andreas
2021-12-22_15h44_25
Do you use that in Python? Then take a look at enum:
Ok! but there is definion clear - i mean a analogy to programming?
I can only work with IN[0] inputs, elements that already in the family
Family type is of data type ElementId. You can use the AsElementId() method on the parameter to convert.
ParameterType is also a class. I don’t know, what you want to do. Show your code because if you try to change familytype, you have to use ElementId Class but if you want to create a parameter with that type then use that class.
