How can I access the control types
Hello Dynos,
how can i access the “flipp” of families? Is there a package? or maybe any python stuff?
I mean just to use “Space” via dynamo.
Kind regards
Andreas
How can I access the flip control type? I’m trying this script but it’s not working on the families I selected import clr
clr.AddReference(‘RevitAPI’)
Function to mirror the element along the FamilyInstance’s internal X-axis
def Mirror_element(item):
try:
# Get the location of the FamilyInstance (assuming it’s a FamilyInstance)
location = item.Location
    # Ensure the item has a valid location (should be a FamilyInstance)
    if isinstance(location, LocationPoint):
        # Get the point of the FamilyInstance's location (center point)
        family_center = location.Point
        # Define the mirror line based on the center of the FamilyInstance, using the internal X-axis (basis X)
        # Mirror line runs along the Y-Z plane at X = family_center.X
        mirror_line = Line.CreateBound(XYZ(family_center.X, 0, 0), XYZ(family_center.X, 1, 0))  # Vertical line along the Y-axis
        # Perform the mirror operation on the element
        ElementTransformUtils.MirrorElement(doc, item.Id, mirror_line)
        return True
        return False  # Not a valid FamilyInstance location
except Exception as e:
    return False  # Handle errors gracefully
items = UnwrapElement(IN[0])
If the input is a list of elements, mirror each one; otherwise, mirror the single element
if isinstance(IN[0], list):
OUT = [Mirror_element(x) for x in items]
OUT = Mirror_element(items)
@tricia.santosTHNQH
better start a new topic! and paste your code in </>
# 🏗️ do something
OUT = "OK!"
