Hello
It is my first topic here.
I’m trying to model reinforcement in double curved sidewalk of a bridge. Sidewalk is a part of a bridge as generic model generated from dynamo to RFA. I attached screenshots. Everything works fine untill hooks orientation of a spacers in distributed rebars. My workflow is:
- I create rebar in a section as a sketch and then manually orient hooks at given angle (no. 1 on screen).
- Then I can manually copy created rebar in section with 0.5m distance. Parameter “Geometry” in this rebar is 1=Free form.
- Next I use script by Dieter Vermeulen from Autodesk to copy transversal reinforcement along path.
- Rebar is distributed but parameter “Geometry” value is changed (to 0=Shape Driven) so new rebars are flat. Here is the problem. I can modify hooks by declarate only Left/Right values.
- I tried to change the value of integer Geometry parameter back to =1 by Dynamo nodes but without success. The parameter is read-only.
- I tried to use python script as you see but without success.
I can upload only 1 picture as new user so I upload other pictures to Google Drive here:
https://drive.google.com/drive/folders/1aV5Eg4DeC_W3zVNY2albIcRrfuR4rVoI?usp=sharing
My investigations:
I read documentation for rebar class:
http://help.autodesk.com/view/RVT/2017/PLK/?guid=GUID-91C5087B-2E92-4276-878B-68FA8491D238
and I think it is possible from the api level to change orientation hooks. To do that I should change the creation method of a rebars (draw each individually by dynamo).
I’ve been struggeling for 2 days to do it by my self but after reading some documentation I think I’m not able to do it without deep understanding of Revit Api. Other discussions ansure me that it’s to hard for me yet:
https://forum.dynamobim.com/t/problems-using-rebarhooktype/17127
I can’t upload files because of company politics but I will try to answer all questions.
Can anyone find sulution?
