Hi there.
I have a library with several classes written in it that I use as interoperability class to exchange data between several software.
I am now trying to use the same .cs within Dynamo but I am not able to hide the public method.
public partial class Vehicle_lib_type
private System.Collections.Generic.List<Caseless_point_load_type> point_loadField;
private System.Collections.Generic.List<Caseless_line_load_type> line_loadField;
private System.Collections.Generic.List<Caseless_surface_load_type> surface_loadField;
private string nameField;
private System.Collections.Generic.List<System.Xml.XmlAttribute> anyAttrField;
/// <remarks/>
[System.Xml.Serialization.XmlElementAttribute("point_load")]
public System.Collections.Generic.List<Caseless_point_load_type> Point_load
get
return this.point_loadField;
set
this.point_loadField = value;
/// <remarks/>
[System.Xml.Serialization.XmlElementAttribute("line_load")]
public System.Collections.Generic.List<Caseless_line_load_type> Line_load
get
return this.line_loadField;
set
this.line_loadField = value;
/// <remarks/>
[System.Xml.Serialization.XmlElementAttribute("surface_load")]
public System.Collections.Generic.List<Caseless_surface_load_type> Surface_load
get
return this.surface_loadField;
set
this.surface_loadField = value;
/// <remarks/>
[System.Xml.Serialization.XmlAttributeAttribute(AttributeName = "name")]
public string Name
get
return this.nameField;
set
this.nameField = value;
/// <remarks/>
[System.Xml.Serialization.XmlAnyAttributeAttribute()]
public System.Collections.Generic.List<System.Xml.XmlAttribute> AnyAttr
get
return this.anyAttrField;
set
this.anyAttrField = value;
The interoperability file should not be touch if possible because also use for other software such as Rhino/Grasshopper.
Can you advise some solution?
What I am trying to do, it is to create a different .cs file for dynamo where I try to extend the class (reason why I am using partial class)
The main idea is to hide all the public methods in the core.cs file in order to don’t create confusion for the user.
