Hide Linked Elements in Active view
clr.AddReference(‘RevitAPI’)
from Autodesk.Revit import DB
from Autodesk.Revit.DB import FilteredElementCollector, BuiltInCategory
clr.AddReference(‘RevitAPIUI’)
clr.AddReference(‘System’)
clr.AddReference(‘RevitNodes’)
view = uidoc.ActiveView
Preparing input from dynamo to revit
linkInst = UnwrapElement(IN[0])
parameterName = “Chamber Depth”
parameterValue = (1800)/304.8
linkDoc = linkInst.GetLinkDocument()
create a category filter
coll = FilteredElementCollector(linkDoc, view.Id).OfCategory(BuiltInCategory.OST_DuctAccessory).WhereElementIsNotElementType().ToElements()
#coll_list = list(coll)
element_to_hide =
for ele in coll:
param = ele.LookupParameter(parameterName)
if param and param.AsDouble() == parameterValue:
element_to_hide.append(ele.Id)
view.HideElements(element_to_hide)
#out.append(ele)
uidoc.RefreshActiveView()
@prasad.chavan
paste your code with </>
clr.AddReference("RevitAPI")
clr.AddReference("System")
# 0️⃣ Preparing input from dynamo to revit
parameterName = "Chamber Depth"
# 1️⃣ create a category filter
# 2️⃣coll_list = list(coll)
element_to_hide = []
for ele in coll:
# 3️⃣ out.append(ele)
KR
Andreas
What’s the reason for automating this? Why not use the Visibility Graphics overrides or a filter?
I was just curious to know if there is a method to hide the linked elements
