Hide/compile Dynamo scripts from end users?
Here is a way to share Dynamo generated geometry without having to share code :slight_smile:
Irrelevant to Revit workflows though.
Geometry is converted to serialized binary stream data using Geometry.SerializeAsSAB and saved to an external file.
Deserialize
Generated geometry could be shared without having to share code.
For example, a designer could share a pattern (with no flexible parameters) without having to share the code that generates it.
This could potentially be incorporated into a workflow that generates Revit elements.
Code for this pattern had been posted here. Hiding nothing
