Dimension.ByElements operation failed. View does not support annotations. Why is this please? Was working the other week now when I load it up it shows this error.
Well as the error suggests i assume it has to do with your active view? Are you using the same view as last week?
Yes, just doing it on the level 1 floor plan which was same view as last week.
Can you show the data in the nodes by showing the previews and pinning them below the node?
Hello from the dynamo player do you have the same result?
Sincerely
christian.stan
