Help with Code Block syntax
Hey quick question.
How can I combine lacing of a sequence within a code block?
The above works, but how can I make the below work that the lacing is not lost and I don’t have to make referals through xlist and ylist etc
@RevitRobot ,
whats your input?
what do you want to create?
KR
Andreas
I want to create parallel lines of 10000 long with each 4000 spacing in between. But every 20 lines I want to create a new set of lines right next to it (hence the 14000).
The input is a list, so I can count how many dots I have to create.
The dots then serve as starting points for the lines.
But my question is how can I have a Code block understand my syntax or grammar so I don’t need to refer to xlist or ylist etc
Amigo @RevitRobot buenas. I know I have a similar script somewhere, but I can’t find it to share it, I only found an image, but maybe it will give you some ideas on how to improve your script, good luck!!
@RevitRobot ,
hmmm…
KR
Andreas
Yeah so why do we have to use t1 and t2.
Why can I not write List.Chop(0…#10000…4000, 2)?
@RevitRobot ,
check out this nice paper
Amigo @RevitRobot, is this what you need??
You have to enclose the range/sequence shortcode in parentheses:
But for the sake of clarity you’d better use the code in the first of your screenshots.
Hey Anton,
I tried that but then I can’t apply the list levels and lacing properly. But I guess that doesn’t matter anymore because I switched to Points.ByCoordinates rather than translating the Origin point
