I was able to ultimately find a solution to my issue. Thank you @Kulkul for you assistance. I was able to generate the below code to produce the information I needed.
cat = UnwrapElement(IN[0])
subcat = cat.SubCategories
listNames = []
listPattern = []
patname = []
listout = []
listpatid = []
for i in subcat:
name = i.Name
listNames.append(name)
id = i.GetLinePatternId(GraphicsStyleType.Projection)
pat = LinePatternElement.GetLinePattern(doc,id)
listPattern.append(pat)
listpatid.append(id)
try:
patname.append(pat.Name)
except:
patname.append("Solid")
style = i.GetGraphicsStyle(GraphicsStyleType.Projection)
listout.append(style)
OUT = listout, listNames, listPattern, patname, listpatid
