help guys i have searched about node for dimension in civil 3D but apparently there is not any node , is there anyones can makes this node,
i would like to do like this picture
thank a lot for help
Or the Arkance Systems Node Library which can be used to create multiple dimensions between a list of points:
hello guy
i am trying to use your great node (aligneddimension.bytwopoint) but i failed can you give us an exemple?
what does mean offset and block ?
The offset input is basically how far you want the dimension text to be away from the line connecting the two points. The block input acts the same was as other nodes - it’s the block where you want to add the dimension (model, paper, or other).
thank you very very much ![]()
