How do you try to create a circle along a line and a minimum number of circles that contain all the points around the line?
I don’t get the problem: you can draw a single circle on a curve that contains all points.
Circle size is limited.
if you are looking for the minumum number of circle, with center on a curve, that envelop all the points given I think you should go for an optimization algorithm, like Refinery, or the older Optimo package.
You will have only 1 objective: minimize the number of circles.
Yes, but I am beginner. So I cannot solve this. But I try to solve it through optimization algorithm. Thank you…
You can find a single minimal circle lying on the line that contains all the points fairly easily:
If you want to have multiple circles, look into a way of clustering the points together and then using the same procedure from above on each cluster.
Thank You. I will try It…
The principle is similar to that suggested above by @Dimitar_Venkov
circles.dyn (7.8 KB)
def dis1 (p:var[]..[],r:var[]..[])
a = Math.Ceiling(List.MaximumItem(p.DistanceTo(r)));
b = r.ClosestPointTo(Point.ByCoordinates(Math.Average(p.X),Math.Average(p.Y),Math.Average(p.Z)));
c = p.DistanceTo(b);
d = List.FilterByBoolMask(p,c <= a);
e = [b,d["out"]];
return e;
def dis2(p:var[]..[],r:var[]..[])
c = [Imperative]
a = dis1(p,r);
b = a[0];
d = a[1];
e = 1;
while (List.Count(d)>0)
f = dis1(d,r);
b[e] = f[0];
d = f[1];
e = e + 1;
return List.Flatten(b,-1);
g = Math.Ceiling(List.MaximumItem(p.DistanceTo(r)));
return Circle.ByCenterPointRadius(c,g);
//Points
a = List.Flatten([(-4..-1..#5),(4..1..#3)],-1);
pts = List.TakeItems(List.Shuffle(List.Flatten(Point.ByCoordinates(a<1>,a<2>),-1)),n);
//Rectangle
rct = Rectangle.ByWidthLength(1,3);
//Circles
cir = dis2(pts,rct);
[pts,rct,cir];
Warning: Multiple definitions for ‘Line’ are found as Autodesk.DesignScript.Geometry.Line, Geometry.Line
you have more “Line” defined in your Dynamo: try to write the full name, like Autodesk.DesignScript.Geometry.Line instead of simple Line.
It should help you with an autocompletition while trying to set it up.
