Hi all,
I am trying to take a rectangle and create internal hatches with a gap tolerance based on an array of points (Created from the rectangle).
Dynamo will take the rectangle (Polyline) and create an array of points within the rectangle. The idea is to then use the traceboundary method or similar on each of these points to test for all objects in the rectangle and then create a hatch from the boundary objects, and if there is a gap, then based on an input tolerance, will ignore it and hatch correctly (Like the hatch command with a tolerance set either with hpgaptol or via the UI)
So far, I have created the script that will create the boundary lines and hatches in modelspace. This works fine for any closed objects like a closed polyline or circle, however if there is an open polyline it will not close it. I have tried a few different methods but I’m not sure if its possible to do this, or at least not with traceboundary. For context, when I recieve a masterplan, i need to hatch all permeable areas for drainage calculations, but often the areas arent closed. I thought that gap tolerance with internal pick hatches would be the best solution. If there is a better way without using this method, please let me know!
For the code used, I am not an expert in Python scripting and only know what i’ve picked up whilst using dynamo, so I have used ChatGPT to assist in writing a decent bit of code, see below:
# Add Assemblies for AutoCAD
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
dataEnteringNode = IN
# Extract input points
points = IN[0]
def create_hatches_from_boundaries(points):
# Initialize an empty list to store hatch objects
hatch_objects = []
# Get the active document
doc = Application.DocumentManager.MdiActiveDocument
# Get the current value of the hpgaptol system variable
gap_tolerance = float(Application.GetSystemVariable("hpgaptol"))
# Get the editor
editor = doc.Editor
# Start a transaction
with doc.TransactionManager.StartTransaction() as t:
# Open the ModelSpace for writing
bt = t.GetObject(doc.Database.BlockTableId, OpenMode.ForRead)
btr = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
# Get the LayerTableId
layer_table_id = doc.Database.LayerTableId
# Loop through each point
for point in points:
# Use TraceBoundary method to create boundary objects
boundary_objs = editor.TraceBoundary(point, True)
# Loop through each boundary object
for boundary_obj in boundary_objs:
# Append the boundary object to the ModelSpace
boundary_object_id = btr.AppendEntity(boundary_obj)
t.AddNewlyCreatedDBObject(boundary_obj, True)
# Set the layer for the boundary object
boundary_obj.LayerId = layer_table_id["_Temp"]
# Create a hatch object
hatch = Hatch()
hatch.SetHatchPattern(HatchPatternType.PreDefined, "SOLID")
# Create a collection for the boundary objects
boundary_object_ids = ObjectIdCollection()
boundary_object_ids.Add(boundary_object_id)
# Append the boundary loop to the hatch
hatch.AppendLoop(HatchLoopTypes.Outermost, boundary_object_ids)
# Evaluate the hatch
hatch.EvaluateHatch(True)
# Set the layer for the hatch object
hatch.LayerId = layer_table_id["HatchAreas"]
# Add the hatch object to the list
hatch_objects.append(hatch)
# Append the hatch object to the ModelSpace
hatch_id = btr.AppendEntity(hatch)
t.AddNewlyCreatedDBObject(hatch, True)
# Commit the transaction
t.Commit()
return hatch_objects
# Call the function with the input points
hatch_objects = create_hatches_from_boundaries(points)
# Output the hatch objects
OUT = hatch_objects
Once created, I use dynamo nodes to handle the objects on the differant layers to remove any duplications and remove the boundary lines, leaving just the hatches so there arent several areas on top of each other.
