The image below is part of code in which im trying to group pipes based on actual distance between their centerlines vs Min(pipe diameters + tolerance (if any)) if distance> Min, I will separate them.
For example here I have 6 pipes, according to this criteria i need to group them in list such that the output is [[0,1],2,[3,4],5]
Hi @ahmed.aelgammal ,
You can use the node Group.ByKey to group your pipes.
According to your script i think you can use your true/false list as keys input
