group-Instance from Elements, how?
Hello Developers,
I almost solved a problem, i want to create a group-instance by Element.Ids. I found a similar node on Clockwork but it creates a type instate of an instance, so how can I change this node:
clr.AddReference('RevitAPI')
element_array = UnwrapElement(IN[0])
assembly_names = IN[1]
assembly_list = list()
# create assemblies
for arr in element_array:
# create a Revit-compatible list of IDs
ids = list()
for elem in arr:
	ids.append(elem.Id)
idlist = List[ElementId](ids)
assembly_list.append(AssemblyInstance.Create(doc, idlist, arr[0].Category.Id))
TransactionManager.Instance.ForceCloseTransaction()
# rename assembly types
i = 0
for assinst in assembly_list:
assinst.AssemblyTypeName = assembly_names[i]
i += 1
OUT = assembly_list
It would be a dream:
Can is say:
group = doc.Create.GroupInstance(items);
is there an instance Method for Groups?
KR
Andreas
2021-02-16_20h47_43
