Hi! I’ve just started learning Dynamo and creating first easy scripts. I created a simple grid generator, which works perfectly fine. I’ve a problem with setting names of those grids. At the end of the chain I use node Elements.SetParameterByName and I get warning “This parameter’s storage type is not a number”. I tried creating new project parameter for grids (both text type and number type) and setting my names there, but I get the same warning. What am I doing wrong?
Hi @TomaszGorecki,
As I see it you’re passing a number value into a string parameter. You can check that with “Object.Type” in Dynamo.
After your Code Block saying “1…9…1”, you should set a node called “String from Object”.
