I am trying to locate the connection point between two walls, and between walls and slabs. Thereafter, somehow be able to add custom properties to this point.
My question is is there a possibility of doing that? and if yes can someone help mw with ideas of doing that. The attached picture is what I have done so far, which I am not sure makes sense, as I am quite new to dynamo.
here is an approach how to solve it. Beginning with extracting all points from elements and removing dublicates you can move on to comparing the points with each other to check if they are the same in two elements.
