Can someone please help me here? Why is Element.ElementType not working?
Hi @mee try element.type + from clockwork should work on link
Hi @sovitek
I’ve been searching for “element.type+” in Clockwork, but I can’t find it? I have the 2.6.0 version. Do you know if it is missing in that version or if it is called something else?
I tried “Linkelement.ElementType” from BimorphNodes, but I get the same error
Hi @mee arhh sorry the name is element.element.type+ it should be there in 2.6, try a search
ps you can use that node from bimorph as well, but then you need use bimorph nodes for get the linked walls. bimorph link element of categori
It is weird because I have been going through all the menues and submenues and I have been searching for it as well - it is not there. I have been looking under the installation folder in my C: drive and I can see it in there. It’s like not all nodes are installed.
I tried to reinstall the package, and I also removed all packages from the install folder, downloaded all of them from scratch and moved then back to the install folder. But it’s still not there.
I will try and have a look on the BimorphNodes to get the linked walls instead.
Ok, so I removed the Bakery package from the install folder, and now all the Clockwork nodes are showing up - also the missing ElementType+!
Great, yes bakery paclakage havent been updatet for years and give conflict for other package, i recommeded dont use bakery
That is a shame. I need to change and update some of my scripts then ![]()
Thank you for your help.
You can probably find something similar in other package, but happy it could work for now ![]()
